I have some question about property
CHASEONHO
18-Opal
Hello
I distinguish data through special key values ​​in the database
and this data is transmitted in real time.
that's why I mash up through templates.
in the tree designed through the network, pass the value of To as the Entity value of the template.
and i update data ussing subscription (AddString(or Integer or Numberic etc..)ValueStreamEntry(params))
but thing's properties do not change.
so I tried the "me.property=item.location" but this method prints the same value in 0.001 second.
I would like to update the properties of this event by avoiding the output at 0.001 second intervals.
this is QueryPropertyHistory
and it is change real time
and this is Property Value
it doesn't change (Here Weight value is default value)
and when i use me.property = item.speed (it's ex)
as you see Output is 0.001s interval about once every 1~4 minutes
and i renewal 1minutes
Please help me
Thank you.
Hi seonho Cha​,
How many properties are you updating in the Service?
Please use UpdatePropertyValues Service and pass current time to update the properties with same time.
about 12
i dont know how to use UpdatePropertyValues Service
var params = {
  values: undefined /* INFOTABLE */
me.UpdatePropertyValues(params);
what is mean??
i don't have infotable..
i have value stream and Thing template
thanks
Hi seonho Cha​,
Please use following Blog Post: How to use UpdatePropertyValues Service in ThingWorx
Ankit Gupta
seonho Cha​,
Do let me know if your issue is resolved? If not, we can discuss further to find a resolution for you.
thanks for your detail.
then i get query property history same time
thanks to your explain
but Thing's property value wasn't change still lol
