I have the url that contains JSON file data, hope to convert into infotable
xcheung
Hi all,
I want to convert JSON file (have url) into infotable, so I:
1.Found snippets have GetJSON function, so i edit the scripts:
var params = {
   // headers: undefined,//"{'data'}" /* JSON */,
    ignoreSSLErrors: true /* BOOLEAN */,
    useProxy: undefined /* BOOLEAN */,
    proxyHost: undefined /* STRING */,
    url:"http://localhost:8080/test" /* STRING */,
    timeout: 500 /* NUMBER */,
    proxyPort: 8080 /* INTEGER */,
    password: "MyPassword" /* STRING */,
    username: "MyUsername" /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
2. Created the DataShape based on the Key of JSON file.
3. After I save the script and test, cannot get the infotable.
Anyone can show the detailed steps to convert from JSON file to infotable? Thanks!
PaiChung
22-Sapphire I
(To:xcheung)
usually you would iterate through the json
use create infotable from datashape
and use create infotable entry from datashape
plus yourinfotable.AddRow(rowObject)
Hi Pai Chung,
Thanks for your reply.
I found the content that directly get from the url is a bit different from the result of GetJSON function. So I changed my AddRow function from ({Name:json.name })to ({Name:data.rows.name}, and then got the correct Infotable, thanks again.
XiaoYing
