I am looking for a solution for Combobox where we can select and search also. Right now I am using List(view: dropsownlist). But it doesn't have facility to search.
Is there any solution for this ?
Raju
There is an extension in the Marketplace that might work for you called autocomplete
Hi pai chung,
It seems that autocomplete cannot be used in Thingworx 7.4. So is there any alternative solution to this requirement?
Thanks!
Xiao Ying
That is strange ... because I'm using it on a project that is using 7.4.
Is the extension not installing for you?
Hi Pai Chung,
After I imported the Autocomplete widget extension from the marketplace in Thingworx 7.4 and placed it in the mashup, I cannot see anything when view the mashup. Even the label of the autocomplete cannot be seen in the mashup, don't know the reason.
P1: test of autocomplete
P2: view mashup (Nothing can be seen)
I found another person have the same problem, maybe we did similar mistakes?
Re: Autocomplete Widget not shown on Mashup in Thingworx 7.4
Oh that is very strange ... not sure what might be the reason, can you try a crtl+F5 on the mashup?
if that doesn't work maybe emptying of browser cache and a tomcat restart
