Please check below service code:
var connections;
if (filter == "blank") {
connections = Networks['FlowServeNetwork'].GetNetworkConnectionsWithTemplate();
} else {
var params = {
start : filter
connections = Networks['FlowServeNetwork'].GetSubNetworkConnectionsWithTemplate(params);
var params = {
dataShapeName : "FlowserveTreeNetwork",
infoTableName : "AssetHierarchy"
// CreateInfoTableFromDataShape(dataShapeName:STRING, infoTableName:STRING("")):INFOTABLE
var assets = Resources['InfoTableFunctions'].CreateInfoTableFromDataShape(params);
var connection;
for each(connection in connections.rows) {
var data = new Object();
data.to = connection.to;
data.from = connection.from;
data.connectionType = connection.connectionType;
var thing = Things[connection.to];
var alert = MediaEntities["YellowAlert"].GetImage();
data.description = thing.description + " " + alert; //appending alert icon with description
assets.AddRow(data);
var result = MediaEntities["YellowAlert"].GetImage();
am unable to append image with text. I have tried keeping description type as text,blob,string in datashape.
am getting error as "[context: com.thingworx.webservices.context.HttpExecutionContext@2ea80460][message: Execution error in service script [FlowserveNetworkServices testImage] : Unable To Convert From [B to INFOTABLE]"
You could try HTML, I know it worked for a text + image for a grid cell (from an infotable);
You cannot add an image to a description, description has to be a string type. What is your use case?
Is there any other type i can keep which will accept String and Image?
I have to display description (string + image) on tree label. Image will be dynamic attached to some description and that description need to be displayed on tree.
So by keeping HTML as base type of one of my infotable fields.. it is possible to do that?
Thanks.. am able to append image to text in infotable.
I would use an infotable so one column carries the text the other the image.
If you are using this in a mashup, you can use state based formatting or use a composite of a value display with image display
I have kept description and image in different column in infotable. But i don't know how to display text+image on tree(text and image will change on logic).
Yes i have to show data in mashup and i have tried using state based formatting for tree but i am able to display icon then text and i need text then icon.
