I'm checking the document Configure PingFederate to Redirect User Login Requests to your IdP for integrating PingFederate with third party IdP, but the link in the picture is not available and display "We were not able to display the page you requested."
Strangely , event in the official website of PingFederate, I got the same error for any of the links below:
How do you read the document of PingFederate ?
Sean
Hi @seanccc.
Thank you for following up to share your findings. Please mark your post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
