If i execute any query service it will take long time respond.
sarathi
If i execute any query service it will take long to respond , Thingworx Server is Configured with postgresql,   So i need to check postgresql health checkup and do i need to run any database Maintenance service separatly?
mnarang
(To:sarathi)
Hi ,
I think you also opened a support case with the same issue .Still if you have huge data in data tables and frequent update/delete operations on the data table .There might be dead tuples occurred in the schema side .That will cause data fetch very slow from the DB .Kindly see this doc for more understanding and to run VACUUM process on the table .
https://www.ptc.com/en/support/article?n=CS261063
Hope it helps
Thanks ,
Mukul Narang
5 REPLIES 5
mnarang
(To:sarathi)
It seems you have postgresql connected as external DB to ThingWorx .And there might be many reasons for long run as the Schema will be prepared by you manually .So if there are select on a large data ,index should be there .Or even there is frequent update/delete on the table ,you should run VACUUM (FULL/VERBOSE/ANALYZE) to check and removal for the possibility of dead tuples .
I hope my understand is correct according to your question ,if the issue is something else then elaborate the use case to understand it better .
Thanks ,
Mukul Narang
sarathi
(To:mnarang)
Hi @mnarang , Thank for your information but Postgressql is defalut thingworx persistance provider, am using default thingworx default schema
mnarang
(To:sarathi)
So that means you are querying ThingWorx schema in PostgreSql as persistence provider .Can you please elaborate ,what kind of query you are firing ? What is the use case here ?
I thought you are trying a SQL query service on a DB thing (Connected to external Postgresql DB) .
sarathi
(To:mnarang)
Hi @mnarang
it is big application, day by day application performance was too slow, Very specific if run service getdatatableentry service on any data table it will take long time service invoke. In our Application there are so many data tables are there, but in the postgres db all the data table are stored in single table named like data_table, Thingworx Data Table are differentiated based on entity id.....we are running more than five projects in single instance,
based on my understanding application side i didnt feel any problem but i thing postgres data table was bloated , please give me suggestion how to avoid table float in postgres, we are using postgres 9.4V, How do we check postgres health checkup continously from thingworx....
mnarang
(To:sarathi)
Hi ,
Hope it helps
Thanks ,
Mukul Narang
