Import Building Block Extension Error
ParthBhadiyadra
11-Garnet
Hello
I am trying to import building blocks in my ThingWorx but can not successfully import getting
another extension like mail extension imported successfully. anyone can help me?
7 REPLIES 7
Please share your application logs. Should be some dependency or build version compatibility issue while import
hi @TanmeyTWX
in application logs, not any new log is displayed like an error or warning
in ss all logs was old log
Need Application and error logs from Tomcat directory. You can find it in below path at your machine.
Program Files--Apache Tomcat -- Logs-- Application and error logs.
Please attach those logs file here.
hi @TanmeyTWX
Thanks for your reply,
My Thingworx was installed in docker, so I copy these logs from a docker container
Below are the last recent logs in the application log file
2023-05-10 12:52:15.460+0000 [L: ERROR] [O: c.t.w.Projects] [I: ] [U: Administrator] [S: ] [P: ] [T: http-nio-8080-exec-1] Entity Not Found : [PTC.DBConnection]
2023-05-10 12:52:15.462+0000 [L: WARN] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [P: ] [T: http-nio-8080-exec-1] Transaction has been marked as a failure for request /Thingworx/Projects/PTC.DBConnection
2023-05-10 12:52:15.577+0000 [L: ERROR] [O: c.thingworx] [I: UI] [U: Administrator] [S: ] [P: ] [T: http-nio-8080-exec-8] ERROR [app-router] Error: Route not found: project-entities
2023-05-10 12:52:15.580+0000 [L: ERROR] [O: c.thingworx] [I: UI] [U: Administrator] [S: ] [P: ] [T: http-nio-8080-exec-9] ERROR [app-router] Router navigation failed, and no previous location or fallbackRoute could be restored.
If you go through your logs you can observe the dependency import error.
Entity Not Found : [PTC.DBConnection]  -this entity is required to make your import successful which is not there already.
I believe [PTC.DBConnection] is the database connection building block which is either not present in the composer or doesn't existing in your import file. You need to figure out this to resolve your issue.
Hope this helps: https://support.ptc.com/help/building_blocks/r1.1/en/index.html#page/bb/building_blocks/database_connection_bb/configuring_what_historical_data_is_logged.html
Hi @TanmeyTWX
In the building block extension zip file contains PTC.DBConnection Project/Entity available
and I have first import PTC.DBConnection and then try to import building block extension but getting same error
Hi @ParthBhadiyadra.
Did you go through this section of the Help Center to make sure you are importing the base configuration first?
--Sharon
