Import Data (.twx) file import failed
SrijithKrish
Hi Team,
I am getting an error while importing a data (.twx) file into my TWX platform.
The data file is almost 105 MB
The error occurring is  :
  • Import failed java.io.EOFException: Unexpected EOF read on the socket {}
  • Failed to close input stream: java.io.EOFException: Unexpected EOF read on the socket
Thanks in Advance
tdixit
(To:SrijithKrish)
Hi @SrijithKrish
Thank you for reaching out to us.
Could you please provide below information
  1. Please let me know if you are able to import any other file apart from (.twx) extension in the platform ?
  2. Please share logs present at location ThingWorxStorage/Logs directory
  3. Please confirm your ThingWorx version
  4. If possible share the sample entity so that we can try to reproduce the issue
Toolika Dixit
Thank You @tdixit for responding
  1. Yes, I was able to import twx files for the sizes varying from a few KB's to 13 MB.
  2. I am not able to share the logs as I do not have access to them.
  3. Sure, our ThingWorx version is 'ThingWorx 8.5.6-b110'
  4. Sorry, I cannot share that information
slangley
(To:SrijithKrish)
Hi @SrijithKrish.
Since you are unable to provide specifics of your issue on the community, I recommend we open a case.  I will be happy to do so on your behalf if you agree.
--Sharon
