Import Failed: The SSO Authentication Type is not set up on this server.
mnalla
7-Bedrock
Hi ,
I installed and configured pingFederate for SSO connection. but while configuring the ptc-windchill-integration-connector the following error is generated.
Can anyone help out me with the issue..?
madhu
7 REPLIES 7
posipova
20-Turquoise
(To:mnalla)
Please refer to this article for troubleshooting help on that error:
https://www.ptc.com/en/support/article?n=CS269460
mnalla
7-Bedrock
(To:posipova)
Hi Polina Osipova,
I had referred to the document but still not able to go further. Could you have any other suggession.
madhu
Vinay_S
(To:mnalla)
Hi Madhu,
Did you find solution for this error even I am stuck with this.
Vinay S.
CADOpt Technologies Private Limited
Bengaluru.
mnalla
7-Bedrock
(To:Vinay_S)
Hi Vinay,
I did not find the solution yet, you can raise a case with PTC, They will help you.
madhu
This error is related to "EnableSSO": true settings from platform-settings.json file.
Ensure that their not extra spaces and syntax is correct. Clear the cache and start the tomcat service again.
Ganesh
ndeshmukh
2-Explorer
(To:mnalla)
You have to enable SSO in platform-setting.json as true
                "PersistenceProviderPackageConfigs": {
                                "PostgresPersistenceProviderPackage": {
                                                "ConnectionInformation": {
        "jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
        "password": "password",
        "username": "twadmin"
                "PlatformSettingsConfig": {
                                "BasicSettings": {
                                                "EnableSSO": true
ndeshmukh
2-Explorer
(To:mnalla)
Please share if you have any SOP for SSO.
