Import Failed
shariharan
7-Bedrock
Import Failed
I'd been working on Thingworx 8.1. Something happened and I had to re-install Thingworx. Now, I'm trying to import my previous work on to the same Thingworx 8.1 Composer and I get the following error:
Any help is appreciated.
Thanks in advance,
Ram
I uninstalled Java and Tomcat and reinstalled and configured the entire environment. Then the import seems to have worked. Any reason as to why this happened?
5 REPLIES 5
posipova
20-Turquoise
(To:shariharan)
Could you please attach your full ApplicationLog.log found in ThingworxStorage/logs?
Please find the attached ApplicationLog file
posipova
20-Turquoise
(To:shariharan)
Do you have all of the same extensions installed as in your original instance?
I only had Thingworx Analytics extension in the previous installation. I have it in this installation too!
