When I try to import, Java heap space appears.
After stopping Tomcat 81 (port used by ThingWorx) I checked that all the related services of the port had disappeared and tried to start Tomcat again.
I added code to the context of Tomcat according to the installation guide.
Also, adding -Xms2048m to the Tomcat manager will not start Tomcat.
How can I get rid of the Java heap space and successfully import?
thank
Please follow the below resolution article for the same. Do let me know in case of any question.
it's cause installed by 32bit
i installed 64bit and import success
my OS is 2012 R2 but, Thingworx matrix said 2012
using 2012 R2 is ok?
thanks
