Hi all,
I want to get data from an excel (.xlsx) file, use it as infotable data and export datatable(grid) to excel (.xlsx) file.
Now, I can only do with csv file but it is not appropriate with my project.
How can i do it with .xlsx file?
Thanks and Regards,
Duong.
Hi @NBHD207.
We don't offer the ablity to import/export using the Excel format. If you need this, it may be necessary for you to write your own extension. This link will provide some guidance to do so.
Perhaps if we knew more regarding your use case, we could provide another option.
--Sharon
Hi @NBHD207.
--Sharon
Hi @NBHD207.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
