I have been importing few of the mashups as a single entity from old instance to new instance .But the issue right now i am facing is it a collection mashup ,when i tried importing whole mashup its is only partically visible and other half disappeard ,i gave permissions for all users and modified service in order to add a line that references these mashups at the end.Still the page is not completely visible.
The application logs weren't helpful but the quick fix was ,remove the bindings from broken mashup and redo binding of the data .(Bind data/services again on the collection widget which every panel view is missing or not showing as expected.).
Could you please open your browser developer tools and see what errors are shown? usually it will indicate what is missing/which piece is at 404. Also might be worth looking into the Applicaton Log. When you log in as an administrator - does the problem persists? It's either permissions or some dependent component missing.
Hi @tashu.
For the benefit of others in the Community, please mark the Accepted Solution if you are satisfied that you have found the answer.
Regards.
--Sharon
