I exported my project to the ThingworxStorage folder, which happened successfully. I want to import the entire thing back to my instance under a different project name, without losing the existing data and entities.
Is it possible to do so?
If yes, how?
Thanks in advance!
I don't think this is possible without going into the xml and changing the xml definition itself.
I don't recommend this, but if this is what you need to be able to do then that is probably a way to do it.
BUT you won't be able to import them into the same instance because of the name conflicts! All your entities will have the same name and therefor overwrite each other.
Being in different projects doesn't prevent that.
Thanks a lot Pai. Will keep that in mind...
