Importing data from an external table
Mr_Henry_M
Hello everyone! I have a table (Excel, for example), the data from which I need to import into Composer. Is it possible? Or does ThingWorx import data only from files with its own format (twx.)? This is about data, not about entities.
1 ACCEPTED SOLUTION
posipova
20-Turquoise
(To:Mr_Henry_M)
You would not be able to import it through Composer data import. You would have to create a javascript service that consumes the data or implement your own custom java extension to do so.
posipova
20-Turquoise
(To:Mr_Henry_M)
Mr_Henry_M
(To:posipova)
Thanks!
