Impossible to send an email to reset password (organization)
pjoly
11-Garnet
Hello
I have put an organization login page in place.
It works fine but I wanted to test the "reset password " feature.
I have the email extension installed and configured (I can send email with it, it tested the service)
I used the corresponding thing for
Password Reset Mail Server?
But when I try to send the email I have the error
Internal Error - unable to send email
I see nothing wrong  in the logs
In security log it seems OK :
User [xxxxxx] is a member of [xxxxxx] and has confirmed their personal information - sending reset email
Any ideas how to configure it to make it works ?
posipova
20-Turquoise
(To:pjoly)
It should be working as an overwrite install of the extension. You may try deleting the original extension, restarting tomcat, installing the new extension.
But first, would it be possible for you to obtain an email account with say, google, and test it? Since the configuration is known and simple, it would be an easier test to ensure the problem lies indeed on the extension side.
For a g-mail account, the settings would be the following:
Smtp.gmail.com 587
Pop.gmail.com 995
Check Use TLS
Please refer to this guide for more details.
Google e-mail and mail extension: set up and troubleshooting
26 REPLIES 26
ankigupta
(To:pjoly)
Hi pjoly​, This seems to be a Bug. Jira TWAPPS-33 is open for this issue.
pjoly
11-Garnet
(To:ankigupta)
OK
As customer (Gold support) do we have an access to these  open Jiras  (I cannot find in my account)  ?
Pascal
supandey
(To:pjoly)
pjoly, you can track the status of the SPR/Jira opened for your issues via the article attached to your case (if you created one with www.support.ptc.com)
Hi Ankit Gupta​, any information if this has been fixed yet? Thanks!
Hi Pascal, the issue is being worked upon at R&D. Fix not ready yet.
Thanks. This is a real blocker to go live with our customers. I asked Stefan Bode​ to upgrade the priority...
Hi pjoly​, any update on this?
Hello
no news, I'll open my own ticket even if they have already in Jira from another customer.
perhaps the more tickets on a subject the highest priority ...
Aanjan
9-Granite
(To:pjoly)
Pascal, what Mail Server is in use? Is this through ThingWorx Utilities? Is the user you're trying to send part of a specific ThingWorx Organization?
pjoly
11-Garnet
(To:Aanjan)
hello
I'm using thingworx mail extension ( 3.3.0) from the market place.
Mail server is postfix on Ubuntu (localhost where thingworx is running)
The user is part of an Organization yes (it's me)
thanks
Aanjan
9-Granite
(To:pjoly)
What Mail Server is it using? I've seen this happen with Yahoo mail but not with Gmail; so we might need to check on any security settings on your Mail Server itself.
pjoly
11-Garnet
(To:Aanjan)
I'm using the same email than during the "test" of the service which is working fine.
So I don't understand why it is not working from the "reset password" button associated with the same service.
pbaierl
(To:pjoly)
I am having the same issue.  I opened a case for this a little while back but haven't heard anything new.  I have just heard that the R&D team is looking into the issue as was mentioned above.
I am using a Microsoft exchange server to send the reset password message.  I am using this same notification thing to send out notifications when my devices go offline so I know that the notification thing does work.
Did you try with a POP3 Server? We had similar Error with Exchange...
posipova
20-Turquoise
(To:pjoly)
If you are using Gmail server, please see Google e-mail and mail extension: set up and troubleshooting
Before you click "reset password", open your browser developer tools, and then see if there are any errors once you run the service. What is the error in the application log? Do you have Thingworx Utilities?
pjoly
11-Garnet
(To:posipova)
Hello
1/ I am not using gmail
2/ I have some error in the console :
404 : https://servername/Thingworx/Common/locales/de/translation-login.json
(why de ? I am in France)
3/ I don't have Thingworx Utilities (I cannot find it in my downlmoad workspace)
posipova
20-Turquoise
(To:pjoly)
If you go to Monitoring -> Application log, can you see any errors? Please copy the error and paste it here. What mail server are you using? If it's corporate, do you know of any possible restrictions  being set up on the incoming messages? Another way to test is to try and set up with a different mail server.
pjoly
11-Garnet
(To:posipova)
Application Log :
A general exception occurred - null
I am using postfix to send and to receive it is another server  associated to the email (gandi)
I can send email by using the service "
SendMessage
I tested another external server from my FAI (working also with send message), same result ...
posipova
20-Turquoise
(To:pjoly)
This error confirms an existing logged defect. The fix should be out next week with the release of the mail extension 3.3.1.
pjoly
11-Garnet
(To:posipova)
hello
I downloaded  and installed extension mail 3.3.1 but same result.
something to restart other than the mashup itself ? (and how to restart the "mail" thing ?)
posipova
20-Turquoise
(To:pjoly)
Smtp.gmail.com 587
Pop.gmail.com 995
Check Use TLS
pjoly
11-Garnet
(To:posipova)
hello
I restarted tomcat8 and it is OK (my SMTP servers were OK as tested separately with "test messages" ) !!
So the procedure I used
1/ Upgrade mail extension to 3.3.1 by overwrite 3.3.0 (just import)
2/ restart tomcat8
that's all
Thank's all for support !
posipova
20-Turquoise
(To:pjoly)
Thank you for the update!
Happy holidays.
sbalta
(To:pjoly)
Can you provide (copy-paste) more lines of logs: before and after "A general exception occurred - null" ?
pjoly
11-Garnet
(To:sbalta)
hello
application logs :
16-12-27 15:24:42.236
WARN
Thingworx System Metrics
SuperUser
c.t.s.s.p.PlatformSubsystem
pool-6-thread-1
2016-12-27 14:54:42.236
WARN
SuperUser
pool-6-thread-1
2016-12-27 14:24:42.236
WARN
SuperUser
pool-6-thread-1
2016-12-27 14:18:32.824
ERROR
c.t.s.a.Authenticator
http-nio-443-exec-4
2016-12-27 14:16:13.458
INFO
*** Import completed successfully
SuperUser
c.t.c.ImportProcessor
http-nio-443-exec-9
2016-12-27 14:16:13.456
INFO
*** Post start notifications for Dependent Thing GandiMail...
SuperUser
http-nio-443-exec-9
INFO
*** Post start notifications for Dependent Thing MailServerM2AIM...
SuperUser
http-nio-443-exec-9
2016-12-27 14:16:13.455
INFO
*** Activating Property Bindings for Things
SuperUser
http-nio-443-exec-9
security log :
2016-12-27 15:34:42.851
WARN
User [Pascal] is a member of [xxxxxx] and has confirmed their personal information - sending reset email
S.c.t.s.a.Authenticator
http-nio-443-exec-2
2016-12-27 15:34:19.591
WARN
Reset Password clicked for [OrgName: xxxxx]
S.c.t.w.BaseService
http-nio-443-exec-3
sbalta
(To:pjoly)
What ThingWorx version are you using?
Are you using special characters in your password? If yes, could you test with simple characters?
Can you reproduce the steps provided by Polina, and tell us the result?
