In DataShapes - what is the difference between effectiveFieldDefinition and fieldDefinition?
ptc-6052641
I'm building an extension that gets a DataShape and work with it fields.
In the JS code I'm getting two field definitions: one called effectiveFieldDefinitoins and one called fieldDefinitions.
What is the difference between the two?
Which one should I use?
mgoel
(To:ptc-6052641)
Hi Amiad Rozenberg
getFieldDefinition Returns:
the FieldDefinition of the field with the supplied name, or null if the field does not exist
GetEffectiveFieldDefinition Returns:
result Field definitions - INFOTABLE - Aspects {dataShape:FieldDefinition}
Throws: java.lang.Exception - If an error occurs
​Regards,
Mohit Goel
