In Menu, default check box is not reflecting in mashup
ad24
As I used the Menu entity in my mashup.Even if checked the default option in menu its still not reflecting in my Mashup.
Please help us on the above issue.
9 REPLIES 9
posipova
20-Turquoise
(To:ad24)
Which version of Thingworx are you using?
ad24
(To:posipova)
I am using Thingworx 7.4 version
ankigupta
(To:ad24)
Hi Aakash D24​,
Just to make sure your Menu or SubMenu items contains Mashup, Hyperlink or logout? Just Menu with Menu sub-items will not show in Mashup.
ad24
(To:ankigupta)
Hi Ankit Gupta
I have mashup in my menu and i have marked it as default but still its not reflecting I dont know why its happening no clue on it.Please help regarding it is there a procedure to use the menu item with default part
ankigupta
(To:ad24)
Hi Aakash D24​,
Can you please attach your entities here to help me check?
ad24
(To:ankigupta)
Which entities i need to attach i am just using a mashup as an menu item and checked as default
ankigupta
(To:ad24)
Aakash D24 Please attach the Mashup entity and Menu entity.
ad24
(To:ankigupta)
Hi ,
Sorry for the delay .On selecting Default check box its not reflecting thats my issue
Ankit Gupta​​ ,
Is this related to the default menu problem being tracked here: Menu default problem....
under Jira TW-10982?
Do you have any updates related to the resolution of this issue or that ticket?
Thank you in advance!
