In adv grid, columns are automatically changing its order in UI. How to stop this behaviour ?
AP_10343008
Iam using Thingworx 9.1.
I still face reordering columns after configured in grid. So I provided ordinal values while defining field definitions. I hope this will fix.
6 REPLIES 6
What do you mean "columns are automatically changing its order in UI"? What is the expected order in UI? Can you provide more detailed information or a demo sample entities?
@AP_10343008 column order can be changed.
If you open the Configure Widget popup as below, you can drag a column and change its displaying order.
Can you check column order is changed or not?
bchaudhary
(To:wcui)
Hello @AP_10343008 ,
Pls share your response so that we can check further for the resolution.
Bhawna
Just a shot in the dark -- did you try to clear your cookies or just open your mashup in Private mode? Grids allow some end-user personalization by persisting their column state in the browser. Maybe what you are seeing is some undesired side effect of that...
Vilia (my company) | GitHub | LinkedIn
slangley
(To:AP_10343008)
Hi @AP_10343008
If one of the previous responses allowed you to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others in the community.  Or post a new response with the details of the solution you found.
--Sharon
