Dear ptc community,
i got a problem and couldn't find an answer like usual. For example my state format is like this now, everything under 30 is red, from 30 to 50 is yellow and 50 to 100 is green. The Problem now is i got like 16 values from 1 to 20000 and everything what is above 100 is automtically green. So my question is there anything like percentage state formatting or some other ways which could help me. Thx in forward.
I don't know if % formatting is possible (yet) or not - I would put that in the Ideas/Request forum.
You can set the limits dynamically, so you can calculate and provide the limits with a service to your widget properties.
When you add state based formatting to a widget, the limits will become available as bindable properties.
To be honest i dont know how i should do that to set them dynamically und put them into a service.
Oh nevermind i got it now thx.
