Is there a way to determine how much RAM an Infotable property is using? Preferably, a method that wouldn't involve setting the infotable, checking the total system memory usage, and then deleting the infotable and doing the subtraction.
Is this infotable invoked/fetched in a Mashup in any way? If so, browser Developer Tools should tell you the size of the data it retrieves as part of the response.
If we're looking at something *huge* (several GB), then a heap dump will come in handy for exact numbers.
Hey Andrew, how about exporting that entity and importing on another instance (and checking memory before and after)
Hey Tudor and Pai,
Thanks for your replies. I went ahead with the method Tudor proposed. It would be nice if you could get statistics on properties as granularly as you can get them for the services.
