Install error with Thingworx Analytics 8.0 on linux
baraspatch
8-Gravel
Hey All,
Just wanted to get some advice on and error i am getting trying to install Analytics 8.0 on linux.
Background
1. Running Cenots 7 64 bit
2. local install of Postgresql 9.5
I have ran the install script using the a local DB with the following setting
port :8097
Host: <ip address>
username : postgres (default superuser)
password: default postgres
Install works fine the and then URL versioninfo works BUT some of the Database tables have not been install , and i would like to understand why and how to fix .
Attached a with the output from a "docker logs analytics" command
Cheers
Paul B
cmorfin
(To:baraspatch)
Hi Paul
The default application id is analytics, I see you are using analytics80, this would not exist by default.
Could you try with analytics (case sensitive) - see https://www.ptc.com/en/support/article?n=CS264461
Hope this helps
Christophe
cmorfin
(To:baraspatch)
Hi
How do you identify that you have got missing tables ?
Are you referring to the messages  of type"DB: table "application" does not exist, skipping" in docker logs analytics output ?
If yes, this output is normal when you start ThingWorx Analytics. I think it happens only the first time while the flyway migration occurs.
So if your statement is based on this output , then do not worry, your installation is fine.
The best is to load a dataset and run some job, so you can confirm it is working.
Hope this helps
Kind regrards
Christophe
Hey Christophe
Thanks for the feedback. I thought as much but as reading your advice i tried restarting analytics and trying to upload a data set. Got these messages and not sure if they are related to the missing application tables.
Any help would be much appreciated
ScreenShot 1 - Related when going into the Data area of the analytics builder page
ScreenShot 2 - Attempt at loading Sample CupCakes.csv
ScreenShot 3 - Confirmation of the connection to the Analytics server thru Composer
Cheers
Paul B
cmorfin
(To:baraspatch)
Hi Paul
Hope this helps
Christophe
CRArko
(To:cmorfin)
Hello, Paul.
Has Christophe's latest reply solved your issue? If so, could you mark this as resolved, and if not, let us know what the current situation is?
Thank you very much,
-- Craig A.
