I’m using a Windows 2019 Server, I have installed Java 1.8.0_231, I have tomcat installed, and I have created the keystore.
Running through the installer, when it gets towards the end, I then get the error below about failure to configure keystore.
Error: "A problem occurred during installation that may cause an unsuccessful installation. Failed to configure installation keystore."
Hi @dwaynelachance.
Windows Server 2019 is not currently supported. Please refer to these instructions for system requirements.
Regards.
--Sharon
Hi @dwaynelachance.
Regards.
--Sharon
Hi @dwaynelachance.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
