Installation Tomcat8 on Ubuntu server 15.10 failed
lchan1
Installed the Ubuntu Server 15.10
Following the installation procedure on manual: Installing ThingWorx 7.1 Version 1.3 Page 20 to 24
Then issue command
$ sudo service tomcat8 start
Job for tomcat8.service failed because the control process exited with error code. See "systemctl status tomcat8.service" and "journalctl -xe" for details.
Then issue command to check
$ sudo systemctl status tomcat8.service
● tomcat8.service - (null)
   Loaded: loaded (/etc/init.d/tomcat8)
   Active: failed (Result: exit-code) since Thu 2016-09-29 17:55:15; 5min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1202 ExecStart=/etc/init.d/tomcat8 start (code=exited, status=203/EXEC)
Sep 29 17:55:15 ubuntu systemd[1]: Starting (null)...
Sep 29 17:55:15 ubuntu systemd[1]: tomcat8.service: Control process exited, code=exited status=203
Sep 29 17:55:15 ubuntu systemd[1]: Failed to start (null).
Sep 29 17:55:15 ubuntu systemd[1]: tomcat8.service: Unit entered failed state.
Sep 29 17:55:15 ubuntu systemd[1]: tomcat8.service: Failed with result 'exit-code'.
$ sudo journalctl -xe
-- The error number returned by this process is 8.
-- Subject: Unit tomcat8.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit tomcat8.service has failed.
-- The result is failed.
Sep 29 17:55:15 ubuntu polkitd(authority=local)[641]: Unregistered Authentication Agent for unix-process:1173:655469 (system bus name :1.17, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Please help to resolve.
What I am missing during the step 1 to 33 in the installation manual for Ubuntu?
What default user should I use during the installation of Ubuntu OS?
Thanks in advance.
Best Regards
C. Louis
lchan1
(To:lchan1)
Problem solved. As Ubuntu 15.10 onward uses only systemd to boot start service.
I create a /etc/systemd.system/tomcat8.service
sudo nano /etc/systemd/system/tomcat8.service
#Start of File
[Unit]
Description = Tomcat8 script that runs a shell script at boot
After = syslog.target
[Service]
Type=oneshot
ExecStart = /usr/share/tomcat8/bin/startup.sh
ExecStop = /usr/share/tomcat8/bin/shutdown.sh
Restart = always
RemainAfterExit = yes
Restart = always
[Install]
WantedBy = multi-user.target
#EOF
sudo chmod 755 /etc/systemd/system/tomcat8.service
sudo systemctl enable tomcat8.service
sudo reboot
#Verify tomcat8.service status.
2 REPLIES 2
lchan1
(To:lchan1)
#Start of File
[Unit]
[Service]
Type=oneshot
Restart = always
Restart = always
[Install]
#EOF
sudo reboot
Hi Louis,
In ubuntu Server 16.04 LTS it didn't work for me, can yo help me?
when i execute:
the output in shell is:
tomcat8.service - Tomcat8 script that runs a shell script at boot
Loaded: loaded (/etc/systemd/system/tomcat8.service; enabled; vendor preset: enabled)
Active: active (exited) (Result: exit-code) since Mon 2017-10-09 21:32:34 UTC; 8min ago
Process: 1384 ExecStart=/usr/share/tomcat8.5/8.5.20/bin/startup.sh (code=exited, status=0/SUCCESS)
Main PID: 1416 (code=exited, status=1/FAILURE)
Oct 09 21:32:34 edoxxiot1 systemd[1]: Starting Tomcat8 script that runs a shell script at boot...
Oct 09 21:32:34 edoxxiot1 startup.sh[1384]: Tomcat started.
Oct 09 21:32:34 edoxxiot1 systemd[1]: Started Tomcat8 script that runs a shell script at boot.
Oct 09 21:32:47 edoxxiot1 systemd[1]: tomcat8.service: Main process exited, code=exited, status=1/FAILURE
Thank you for you time,
Best regards
