I have been trying to install TW but I must be doing something wrong. keystore-password file was generated in my ThingworxPlatform folder, containing string ending with equal sign.
When I access url with Thingworx I get completely white page.
Here are some maybe relevant Logs from Tomcat
stderr
03-Oct-2017 17:12:50.625 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
stdout
2017-10-03 17:12:42 Commons Daemon procrun stdout initialized
Attempting to load ESAPI.properties via file I/O.
Attempting to load ESAPI.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\ESAPI.properties
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\validation.properties
Loaded 'validation.properties' properties file
*** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
*** Web Application STATE is being set to ERROR! ***
Thank you for any advice in advance
Jara
What database is it? Seems like it cannot establish the database connection.
You may also refer to Frequently Seen Errors upon launching the Thingworx application:
Its PostgreSQL.
I successfully ran the bat files.
The only thing I havent done was to
Modify the /pg_hba.conf file and add the following lines based on your desired configuration:
If you want to allow all IPv4 addresses to connect: host all all 0.0.0.0/0 md5
but that is not needed if i have TW and database on one server, right?
Edit:
in path C:\ThingworxStorage\PG_9.4_201409291\17490
there are many files. And they are related to Postgre, arent they?
That should be for the HA configuration. Could you please expand the thingworx database in the pg admin III and keep expanding until you see the number of tables created? How many are there?
Also what is your platform-settings.json looking like?
There are 58 tables.
This is my platform settings file
"LicensingConnectionSettings":{
"username":"...",
"password":"...",
"activationIds":"key1, key2, key3, key4"
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
"password": "...",
"username": "twadmin"}}}
Update:
I changed authorization for twadmmin user and I had probably wrong password in platform setting file. Now when I try to access TW url it is spinnning indefinetely. I checked th location of java.dll. It seems OK.
New LOGS:
03-Oct-2017 19:39:46.103 SEVERE [ContainerBackgroundProcessor[StandardEngine[Catalina]]] org.apache.catalina.startup.HostConfig.deployWARs Error waiting for multi-thread deployment of WAR files to complete
java.lang.InterruptedException
at java.util.concurrent.FutureTask.awaitDone(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:744)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:407)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1595)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:280)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:94)
at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1164)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1388)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1392)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1360)
at java.lang.Thread.run(Unknown Source)
2017-10-03 19:21:54 Commons Daemon procrun stdout initialized
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
Expecting an absolute path of the library: FlxCore64.dll
Hi Jaroslav,
Have you set the library path to the PATH variable in the system environment variables?
If you haven't done so, could you please try the steps given in the following thread and let us know the result:
It didnt help me.
03-Oct-2017 20:39:32.577 INFO [localhost-startStop-1] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
System property [org.owasp.esapi.opsteam] is not set
System property [org.owasp.esapi.devteam] is not set
catalina
03-Oct-2017 20:39:26.055 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx.war
03-Oct-2017 20:39:32.483 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
2017-10-03 20:39:24 Commons Daemon procrun stdout initialized
Jaroslav ,
Could you attach your complete Application log file present in the ThingworxStorage/logs folder?
