Hi All,
I have an infotable that has missing values (interpolate_1),
I use the following code (interpolate_params) to try and fill the gaps by the last element.
var params = {
mode: "INTERVAL" /* STRING */ ,
timeColumn: "timestamp" /* STRING */ ,
t: loggedValues /* INFOTABLE */ ,
ignoreMissingData: false /* BOOLEAN */ ,
stats: "LAST" /* STRING */ ,
endDate: endDate /* DATETIME */ ,
columns: "p1_plasma__cooling_water__conductivity__actual;p1_plasma__cooling_water__conductivity__limit_high" /* STRING */ ,
count: 1000 /* NUMBER */ ,
startDate: startDate /* DATETIME */
// result: INFOTABLE
var interpolatedLogged = Resources["InfoTableFunctions"].Interpolate(params);
For some reason, the gaps are not filled, and the timestamp is not stretched correctly.
Please let me know what am I doing wrong ?
Hi Costantine,
Thank you for your answer.
You are correct, "SMOOTH" works fine and as expected. However, when I put mode to "LAST", it only takes the last value for one element and does not replicate that value if you have more than one consecutive empty value.
I am not sure if this is the real intention of the function or it is a bug in the function.
Thank you for your test
Hi @ronyT.
The screenshots are from different dates, so we can't really tell anything from them. Using the LAST method, the value for the new data point should be the last value in that interval. Did you validate that there are values in the intervals you are reviewing?
We may need to open a case for this to determine if there is actually an issue in the product. If so, we would follow up to report it as a defect.
Please let me know if you would like me to open a case on your behalf.
Regards.
--Sharon
I make sure I have the first row (oldest value) filled in the infotable before calling the interpolate. I always pass an infotable with at least the first row completely filled. When I change the mode to "SMOOTH" it works nicely, however with "LAST", it doesnt.
I made a workaround by using a double for loop (looping over fields, then looping over all rows) and fill the gaps by the last value.
I also opened a support ticket for that and waiting for an answer
Thank you.
There are ways to do this, but like all interpolation methods, you need to have data at a scale smaller than the spatial scale of variations in the true surface being estimated. This is generally assumed, but not always correct. A good example is the problem with interpolating rainfall data.
