Interpolate function not working as expected
- March 30, 2020
- 2 replies
- 3712 views
Hi All,
I have an infotable that has missing values (interpolate_1),
I use the following code (interpolate_params) to try and fill the gaps by the last element.
var params = {
mode: "INTERVAL" /* STRING */ ,
timeColumn: "timestamp" /* STRING */ ,
t: loggedValues /* INFOTABLE */ ,
ignoreMissingData: false /* BOOLEAN */ ,
stats: "LAST" /* STRING */ ,
endDate: endDate /* DATETIME */ ,
columns: "p1_plasma__cooling_water__conductivity__actual;p1_plasma__cooling_water__conductivity__limit_high" /* STRING */ ,
count: 1000 /* NUMBER */ ,
startDate: startDate /* DATETIME */
// result: INFOTABLE
var interpolatedLogged = Resources["InfoTableFunctions"].Interpolate(params);
For some reason, the gaps are not filled, and the timestamp is not stretched correctly.
Please let me know what am I doing wrong ?
