Hi everyone.
I have created a service that adds stream entries to only a few specified columns if a certain boolean condition is true. If the boolean condition is false then the service updates the stream entry by filling in the rest of the column values. I passed the infotable that holds the values and a current streamID to the updateStreamEntries snippet.
This does not work, I keep getting the error : Invalid number of values provided to UpdateStreamEntry.
How can I fix this?
You can only pass one entry to update to the service. So the values parameter cannot have more than one row if you use UpdateStreamEntry.
