from the subject, running 6.12 ThingWorks KEPWare Server with IoTGateway REST Server configured as write enabled (for endpoints).
When attempting to write a value to a tag through REST call, the following is returned:
"writeResults": [
"id": "<tag_name>",
"s": false,
"r": "Request rejected."
The issue was the tag had a "default" datatype, it had to be specified.
HI @MS_9937986 - You've not supplied a whole lot of information on what you're trying to do in order to guide you (as in your server application with REST endpoint, auth mechanism, etc.). I'd suggest that you look at the server side access log as this should give you an indication of why the request was refused.
