Is Edge Micro Server (EMS) available in C++ language?
jhooda
I am looking to install EMS agent in a machine that doesn't support Java. So what other options do I have?
preddy-2
7-Bedrock
(To:jhooda)
Check whether you can do it with C edge sdk. That can be easily integrated with C++.
With B/R,
Praveen.B
ibanham
(To:preddy-2)
Options:
1) The Edge Micro Server/Lua Script Resource - this is a pair of configurable executables that make a ThingWorx Agent. There are a selection of these depending on the chipset you are using. The EMS and LSR do not require Java.
2) C SDK. The smallest of the Edge SDKs in terms of footprint.
