Hi everyone,
i need one help, actually i need to disable the click function in the list widget. is any option is there to do that ?(through service or any other method)
thanks
Dinesh
Only if it is in a static mashup or in a panel, you can overlay a shape on top of the list with no fill and set the z-index higher than the list widget.
Hi James McCuen,
it is working fine .thank you..
DINESH
