Is There any problem with MQTT on thingworx experiance url?
ppradhan-2
getting isConnection = false i can connect to my localhost but not to the thingworx experiance url.
Hi pravin pradhan​,
Which port are you using for MQTT 1883 or 8883 (SSL)?
i am using 1883 port
i wanted to send json data from raspberry .py program to thingworx experience url so that to use in Thingworx studio and the same is working fine with my local system thingworx but not able to establish connection with thingworx experience url and mqtt
Hi Ankit Gupta​ is it any version issue? or Thingworx experiance url doesent support it?
