Is azure blob storage account hot or cold?
GuruPrasad1
Configuring the Thingworx azure IoT hub connector requires creating a blob storage, should this storage account be Hot or Cold Storage?
Hi
Got the answer in the installation guide available at developer portal.
https://developer.thingworx.com/en/resources/guides/install-azure-iot-hub-connector/configure-azure-iot-hub
Go To Step 2:
Answer: The azure blob storage should be Hot Tier.
It says "NOTE: Select Blob storage as the account type and the Hot Access Tier".
We are asking internally this question and I will come back to you.
Raluca Edu
dupatel
(To:GuruPrasad1)
@GuruPrasad1  I believe it depends on the use case/requirement/budget to go for any specific Azure blob storage type i.e. hot or cold.  Is there any specific use case you have and can share details?
As such, there is no restriction to use any specific storage type which I know and can refer the help center details as well for details  -
http://support.ptc.com/help/thingworx_scm_azure/r3.0/en/index.html#page/thingworx_scm_azure%2Fazure_connector%2Fc_azure_connector_up_and_running.html%23
-Durgesh
Hi
Go To Step 2:
