Is it a bug? only double click datetime picker widget can be displayed ,one click should force close.
lli-31
I use Thingworx 8,the problem is happen at Firefox or IE 11.
7 REPLIES 7
supandey
(To:lli-31)
Hi Lianyi li, could you share exactly which datecode for ThingWorx 8 and bit more description about the issue? I just tried with 8.0.1 and i can use the dateTime picker without any issue.
Sushant Pandey,  Additional my tested mashup export file.
supandey
(To:lli-31)
Thank you Lianyi, i'll check this out. Though unfortunately i will only be able to test it on EN OS. But will let you know of the test result.
Thanks Sushant Pandey for reply,.I have try to tested datetime piker  several times,and I compare it  diferences run in IE 11 and orther Explorer can run right,.
then I just place a datetime picker on a mashup:
1、After clicked datetime picker widget,texts in widget should have a little move up and down, I guess it maybe cause to  make opened panel closed.
              befor click
             after click
2、The widget height became small than in other Explorer can run it right..
3、I run Thingworx and IE on Chinese language environment.
My IE version as below:
 When datetime picker do not work orrect in IE 11, but datetime picker in  time selector widget can work  at sametime.
The datetime picker is running OK on IE11 when I upgrade Thingwox from v8.0.0 to v8.0.3
mnarang
(To:lli-31)
lianyi li​ - I checked this on Thingworx 8.0 (IE 11) and also on the previous version 7.4.2 (IE 11) .This widget is working in same fashion on both cases .On single click it's opening up and you just select the date and press done for close .This is how it's is designed .If you need some custom feature you may take a copy of this widget and try some hands on .
Mukul Narang
