Is it possible to assign the popup width and height in Service?
Sankarapandian
6-Contributor
I'm having Service which will returns the Mashup name as result output based on condition. I will bind the service result (Mashup Name) to the navigation widget. Here we can assign only the fixed popup width and height . This popup size will be same for All popups. But My requirement is I want to Show the Popups with different size based on mashup name. Is this possible? Kindly Let me know if there any solution available for my requirement.
Thanks in Advance
Sankarapandian. L.S
Hi @Sankarapandian
Also in ThingWorx 8.5 there is a new Navigation function that allows to bind the popup height and width and so could take this as from your service together with the mashup name - see Help Center for more info about it.
Hope this helps
Christophe
Hello @Sankarapandian,
I'm not sure it's possible, but there's a workaround that may work for you. Just use several Navigation functions, each one for its own mashup, and choose between them via Validators. This approach works well for a small number of mashups, e.g. less than 5.
Constantine
Hi @Sankarapandian
Hope this helps
Christophe
Thanks for your response. It's working fine.
