Is it possible to use the keyboard up and down arrow keys for selecting rows in the collection widget?
@Vishnu_K : I checked at my end. For tab sequencing as well, there is no OOTB functionality provided for collection widget. You would need to rely on the default tab sequencing .
Hi @Vishnu_K
It doesn't appear that you will be able to use arrow keys to navigate, but you can use the tab key to advance based on the tab order you have set, cell by cell.
Which version of ThingWorx are you using?
--Sharon
I am using Thingworx 8.5.6
The scenario is that there is a collection widget inside a container and is not able to see the 'TabSequence' property in the collection widget.
