Is it possible to convert Infotable into XML
ldas1
I was trying to update a part of element in edge.xml file, for that I tried the converting edge.xml file to infotable and then written the modification code, now in order to write the file back to repository I need my infotable to convert back to XML format. How can I make it possible.
4 REPLIES 4
PaiChung
22-Sapphire I
(To:ldas1)
There are JSON to XML converters, that probably would be the easiest route.
ldas1
(To:PaiChung)
Thanks for the suggestion, but my result is coming in the form of Infotable,
ankigupta
(To:ldas1)
Hi Lipsa Das​,
You can change Infotable to JSON simply by:
var params = {
    table: undefined /* INFOTABLE */
// result: JSON
var result = Resources["InfoTableFunctions"].ToJSON(params);
ldas1
(To:ankigupta)
Thanks but can you also give me the example of JSON to XML conversion because I want my result to come as an XML Format
