Hi ,
I couldn't find the widget "layout" in ThingWorx 8.5.5 while it exists in 8.5.4 and previous versions .
If this widget is obsolete in 8.5.5 , which widget can be used to implement a sidebar which supports expand & collapse ?
Sean
And in the new container, there is a checkbox for EnableExpandCollapse in the setting field,which enables it to work as sidebar.
seem so.
You can change/add the container in mashup directly.
It's in upper left corner, widgets/ mashups/ Layout/ Explorer
@zyuan1 ,
Thank you, Yes, the new container can also support sidebar with EnableExpandCollapse.
Sean
