I'm working with an external service where I request a csrf token via request header and the service returns the token in the response headers. I can't see how to access the response headers in my Thing service.
For example, here's the call to GetJSON:
var params = { |
headers: {'x-csrf-token' : 'fetch'} /* JSON */,
ignoreSSLErrors: true /* BOOLEAN */, | |||||
url: me.baseURL /* STRING */, | |||||
password: me.password /* STRING */, | |||||
username: me.userId /* STRING */ |
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
I can see my request headers in the output if I logger.warn(JSON.stringify(result)); (i.e. {"headers":{"x-csrf-token":"fetch"}) but when I execute the same GET from POSTMAN and look at the response headers, I see the other system's returned value for x-csrf-token.
Is there a way to access the response headers in a service?
Steve Ashley
Hi Steve,
I don't know if that's the reason, but it's not the same doing a request with POSTMAN and with TW, as POSTMAN automatically adds requests headers which can affect to response headers.
Carles.
Hi Steve,
I believe there is no such possibility OOTB now (but I can be wrong). The easiest way to achieve that is to create a very simple extension in Java with generic service to send HTTP requests. Then you can do pretty much anything with response. This is the most clean and straightforward solution.
J.
