Is there a way to integrate Microsoft Dynamics with Thingworx?
abhiramk
11-Garnet
Is there a way to pull data from Microsoft Dynamics to Thingworx? Any integrator available?
-thanks,
Abhiram
4 REPLIES 4
You could use ThingWorx Flow. Out-of-the-box Dynamics 365 connector
Hi Janardan,
Thank you for your response!
Is there any connector available to interact with Dynamics without using Flow? Similar to SAP OData connector? Do we have anything such for Microsoft Dynamics?
BryanK
(To:rjanardan)
This only integrates with CRM, which is not that helpful. We are looking for integration to Dynamics 365 Finance and Operations.
Really need a solution for this.
Hello @abhiramk ,
After doing research on the web, it would seem that you need to configure Connected Field Service (CFS) for IoT Hub from Azure IoT Hub, you would need an Azure account. Connected Field Service is included with Dynamics 365 Field Service.  More info here https://docs.microsoft.com/en-us/dynamics365/field-service/installation-setup-iothub
From a broad picture perspective, this would connect to ThingWorx through a Azure IoT Connector which you can find here https://marketplace.ptc.com/apps/193323/azure-iot-connector-extension#!overview
Hope it helps,
