Or do HTML files need to be hosted remotely? (I'm looking to add HTML5 functionality inside a Mashup).
Please note that there are risks involved with this, so with taking that into proper consideration, you could put your HTML5 pages on a location on the server and do a ../myfolder/mypage.html type reference to it.
Since all Thingworx widgets/mashups are HTML5 what type of functionality are you trying to add? It might be best to add it as Widget Extensions.
Thanks for the reply.
I've developed a 3D visualisation in Unity, which has been compiled to WebGL. Is there a better way of doing this using Widget Extensions?
Thanks.
