Is there any easy way to play sound in mashup? Thanks.
Max Chen, you can create a custom extension (or widget) and include a HTML5 "Audio" tag in a mashup.
You can also use Javascript to programmatically include the above HTML5 tag in a mashup.
Can you also try the "HTML5 Video" extension ?
We are looking forward to know on which path you've went regarding this topic.
