Is there any recommended way to view Neo4j database behind Thingworx 6.x?
I would love to have access too, once I had to access to it and I had to send to TW R&D to get the problem corrected
I would like to do the same: access neo4j database behind Thingworx 6.x
James, is there any particular reason since it's strongly recommended against changing anything directly on the Database, while by passing the ThingWorx application in between.
Any direct change there could lead to data loss/corruption.
If it's just about viewing the structure you can use Neo4j community edition tool. I believe you'll need one of the older release 2.x to be able to connect.
