Is there any way to customise the font of grid widget based on any condition
KV_10974131
Hello
I have a mashup with grid widget and i want to customize the font based on certain conditions of rows. Is there any sample entities or ideas available to do so?
Hello @KV_10974131 ,
If you are planning to customize grid header label, you can use the following article containing custom css to do so:
https://www.ptc.com/en/support/article/CS377793
And for resizing the dynamic text inside a Grid widget using Custom CSS can be achieved through the belowlinked article:
https://www.ptc.com/en/support/article/CS300470
You need to apply the Custom CSS and steps mentioned in the article.
Pls let me know if you need anything further.
Regards
Bhawna
3 REPLIES 3
Regards
Bhawna
Also refer the below linked article having solution for grid issues:
https://www.ptc.com/en/support/article/CS367776
Bhawna
Hello @KV_10974131
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
