I'm trying to identify missing values from a each entry of an infotable, Field values of input infotable are dynamic.
I need to find the count of missing values from each row and also the field names.
Anyone please give me some idea to do this.
Hello @BhavyaPC
I have created small script to iterate over infotable and field definition, try this script
var infoTable = YOURINFOTABLE;
var dataShapeFields = YOURINFOTABLE.dataShape.fields;
for (var i = 0; i < YOURINFOTABLE.length; i++) {
for (var fieldName in dataShapeFields) {
if(YOURINFOTABLE.rows[i][fieldName] == null )
// Add your field, row and count in Infotable or array
Hello @BhavyaPC
