Issue installing thinworx 8
shukhandelwal
I am installing thingworx 8 on windows box having windchill 11 m030, & tomcat 8.5 along with postgresql9.4 but having an error when trying to hit Thingworx ,
The error is: The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
9 REPLIES 9
Hi Shubham,
Could you please share the application.log from ThingWorxStorage folder to track the issue?
java.io.IOException: The system cannot find the path specified
at java.io.WinNTFileSystem.createFileExclusively(Native Method) ~[na:1.8.0_144]
at java.io.File.createNewFile(Unknown Source) ~[na:1.8.0_144]
at com.thingworx.platform.security.keystore.ThingworxKeyStore.createKeyStorePasswordFile(ThingworxKeyStore.java:87) ~[thingworx-platform-common-8.0.1-b39.jar:na]
at com.thingworx.system.configuration.PlatformSettings.<init>(PlatformSettings.java:508) ~[thingworx-platform-common-8.0.1-b39.jar:na]
at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:803) ~[thingworx-platform-common-8.0.1-b39.jar:na]
at com.thingworx.security.authentication.HAAuthenticationFilter.init(HAAuthenticationFilter.java:36) ~[thingworx-platform-common-8.0.1-b39.jar:na]
at org.apache.catalina.core.ApplicationFilterConfig.initFilter(ApplicationFilterConfig.java:285) [catalina.jar:8.5.23]
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:266) [catalina.jar:8.5.23]
at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:108) [catalina.jar:8.5.23]
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4591) [catalina.jar:8.5.23]
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5233) [catalina.jar:8.5.23]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) [catalina.jar:8.5.23]
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752) [catalina.jar:8.5.23]
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728) [catalina.jar:8.5.23]
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734) [catalina.jar:8.5.23]
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:988) [catalina.jar:8.5.23]
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1860) [catalina.jar:8.5.23]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [na:1.8.0_144]
at java.util.concurrent.FutureTask.run(Unknown Source) [na:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.8.0_144]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_144]
14:28:27.192 [localhost-startStop-1] INFO  o.t.w.f.urlrewrite.UrlRewriteFilter - destroy called
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
14:28:27.394 [localhost-startStop-1] DEBUG c.t.reporting.EncryptedJSONReport - PropertyWriteReport executor service shutdown normally within soft timeout.
14:28:27.410 [localhost-startStop-1] DEBUG c.t.s.s.f.e.InMemoryTransferJobOfflineQueueService - FileTransferEviction executor service shutdown normally within soft timeout.
14:28:27.410 [localhost-startStop-1] ERROR S.c.t.w.context.ThreadLocalContext - Failed to retrieve SSOContext
2017-10-04 13:14:37.741+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-10-04 13:14:37.743+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2017-10-04 13:14:37.743+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-10-04 13:14:37.747+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 7
2017-10-04 13:14:37.747+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 4
2017-10-04 13:14:37.747+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 4
2017-10-04 13:14:37.747+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b53
2017-10-04 13:14:37.750+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 941
2017-10-04 13:14:37.751+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-10-04 13:14:37.751+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2017-10-04 13:14:37.751+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Windows 7
2017-10-04 13:14:37.751+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2017-10-04 13:14:37.752+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 6.1
2017-10-04 13:14:37.756+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 8
2017-10-04 13:14:37.756+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: UTF-8
2017-10-04 13:14:37.756+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2017-10-04 13:14:37.756+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_144
2017-10-04 13:14:37.756+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: C:\Program Files\Java\jre1.8.0_144
2017-10-04 13:14:37.757+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 8110 (MB)
2017-10-04 13:14:37.757+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-10-04 13:14:37.757+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2017-10-04 13:14:38.426+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] HA mode not enabled. Initializing and starting in standalone mode.
2017-10-04 13:14:38.426+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Name = ThingworxPersistenceProvider
2017-10-04 13:14:38.426+0530 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Package Name = PostgresPersistenceProviderPackage
2017-10-04 13:14:38.435+0530 [L: INFO] [O: c.t.p.p.PostgresDatasource] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Reading configuration from configTableCol
2017-10-04 13:14:38.674+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Managers...INITIALIZED
2017-10-04 13:14:38.676+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Database initialization started...
2017-10-04 13:14:39.029+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking started...
2017-10-04 13:14:39.050+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking complete
2017-10-04 13:14:39.190+0530 [L: INFO] [O: c.t.p.p.d.PostgresModelDao] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Fetch Size Set - [5000]
2017-10-04 13:14:39.992+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing entities
2017-10-04 13:14:40.030+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ModelTags
2017-10-04 13:14:40.030+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing DataTags
2017-10-04 13:14:40.031+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Groups
2017-10-04 13:14:40.037+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Organizations
2017-10-04 13:14:40.167+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Logs
2017-10-04 13:14:40.206+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing DataShapes
2017-10-04 13:14:40.221+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ThingShapes
2017-10-04 13:14:40.223+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ThingPackages
2017-10-04 13:14:40.722+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ThingTemplates
2017-10-04 13:14:40.722+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Dashboards
2017-10-04 13:14:40.726+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing LocalizationTables
2017-10-04 13:14:40.728+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing StateDefinitions
2017-10-04 13:14:40.746+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing StyleDefinitions
2017-10-04 13:14:40.747+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Widgets
2017-10-04 13:14:40.759+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Mashups
2017-10-04 13:14:40.761+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Menus
2017-10-04 13:14:40.772+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing MediaEntities
2017-10-04 13:14:40.772+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Networks
2017-10-04 13:14:40.773+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Authenticators
2017-10-04 13:14:40.773+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing PersistenceProviderPackages
2017-10-04 13:14:40.773+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing DirectoryServices
2017-10-04 13:14:40.774+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Resources
2017-10-04 13:14:40.777+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing ScriptFunctionLibraries
2017-10-04 13:14:40.780+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Subsystems
2017-10-04 13:14:40.783+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Importing Things
2017-10-04 13:14:40.783+0530 [L: INFO] [O: c.t.c.Import] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Initial import of entities completed successfully
2017-10-04 13:14:40.796+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing new entities
2017-10-04 13:14:40.796+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing ModelTags
2017-10-04 13:14:40.796+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing ModelTags Applications
2017-10-04 13:14:40.826+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added ModelTagVocabulary [Applications]
2017-10-04 13:14:40.830+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing DataTags
2017-10-04 13:14:40.830+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing Groups
2017-10-04 13:14:40.830+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Groups Users
2017-10-04 13:14:40.838+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Group [Users]
2017-10-04 13:14:40.838+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Groups Developers
2017-10-04 13:14:40.840+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Group [Developers]
2017-10-04 13:14:40.840+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Groups Designers
2017-10-04 13:14:40.843+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Group [Designers]
2017-10-04 13:14:40.843+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Groups Administrators
2017-10-04 13:14:40.845+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Group [Administrators]
2017-10-04 13:14:40.845+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Groups SecurityAdministrators
2017-10-04 13:14:40.847+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Group [SecurityAdministrators]
2017-10-04 13:14:40.847+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing Users
2017-10-04 13:14:40.847+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing Organizations
2017-10-04 13:14:40.847+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Organizations Everyone
2017-10-04 13:14:40.860+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Organization [Everyone]
2017-10-04 13:14:40.864+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Organizations Development
2017-10-04 13:14:40.866+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Organization [Development]
2017-10-04 13:14:40.867+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing Logs
2017-10-04 13:14:40.867+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Logs SecurityLog
2017-10-04 13:14:40.875+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Log [SecurityLog]
2017-10-04 13:14:40.875+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Logs ScriptLog
2017-10-04 13:14:40.877+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Log [ScriptLog]
2017-10-04 13:14:40.877+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Logs ConfigurationLog
2017-10-04 13:14:40.879+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Log [ConfigurationLog]
2017-10-04 13:14:40.879+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Logs ApplicationLog
2017-10-04 13:14:40.881+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Log [ApplicationLog]
2017-10-04 13:14:40.881+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing Logs CommunicationLog
2017-10-04 13:14:40.883+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added Log [CommunicationLog]
2017-10-04 13:14:40.883+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Processing DataShapes
2017-10-04 13:14:40.883+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes WikiPage
2017-10-04 13:14:40.890+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [WikiPage]
2017-10-04 13:14:40.896+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DesignTimePermissions
2017-10-04 13:14:40.898+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DesignTimePermissions]
2017-10-04 13:14:40.898+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NamedVTQ
2017-10-04 13:14:40.899+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NamedVTQ]
2017-10-04 13:14:40.900+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DashboardItemParameter
2017-10-04 13:14:40.901+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DashboardItemParameter]
2017-10-04 13:14:40.902+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes UserStatus
2017-10-04 13:14:40.904+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [UserStatus]
2017-10-04 13:14:40.904+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityReferenceWithDescription
2017-10-04 13:14:40.905+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityReferenceWithDescription]
2017-10-04 13:14:40.906+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RootEntityListWithPermissions
2017-10-04 13:14:40.908+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RootEntityListWithPermissions]
2017-10-04 13:14:40.908+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingRelationship
2017-10-04 13:14:40.910+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingRelationship]
2017-10-04 13:14:40.910+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ProjectInfo
2017-10-04 13:14:40.913+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ProjectInfo]
2017-10-04 13:14:40.919+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TimerEvent
2017-10-04 13:14:40.921+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TimerEvent]
2017-10-04 13:14:40.921+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Thing
2017-10-04 13:14:40.923+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Thing]
2017-10-04 13:14:40.923+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes CommonFacets
2017-10-04 13:14:40.924+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [CommonFacets]
2017-10-04 13:14:40.924+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityUsage
2017-10-04 13:14:40.926+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityUsage]
2017-10-04 13:14:40.926+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LongRangeAlert
2017-10-04 13:14:40.927+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LongRangeAlert]
2017-10-04 13:14:40.927+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LanguageDescription
2017-10-04 13:14:40.928+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LanguageDescription]
2017-10-04 13:14:40.928+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TransferReservation
2017-10-04 13:14:40.929+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TransferReservation]
2017-10-04 13:14:40.930+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BooleanValueStream
2017-10-04 13:14:40.931+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BooleanValueStream]
2017-10-04 13:14:40.935+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RootEntityList
2017-10-04 13:14:40.937+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RootEntityList]
2017-10-04 13:14:40.938+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NetworkConnectionWithTemplate
2017-10-04 13:14:40.939+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NetworkConnectionWithTemplate]
2017-10-04 13:14:40.940+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ApplicationKeySecurityEvent
2017-10-04 13:14:40.941+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ApplicationKeySecurityEvent]
2017-10-04 13:14:40.942+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ExportFile
2017-10-04 13:14:40.943+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ExportFile]
2017-10-04 13:14:40.944+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NotificationHandlerDetails
2017-10-04 13:14:40.945+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NotificationHandlerDetails]
2017-10-04 13:14:40.945+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RouteDefinition
2017-10-04 13:14:40.947+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RouteDefinition]
2017-10-04 13:14:40.947+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SpotlightSearch
2017-10-04 13:14:40.949+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SpotlightSearch]
2017-10-04 13:14:40.949+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes VocabularyTerm
2017-10-04 13:14:40.951+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [VocabularyTerm]
2017-10-04 13:14:40.955+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RelatedMashup
2017-10-04 13:14:40.956+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RelatedMashup]
2017-10-04 13:14:40.957+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Group
2017-10-04 13:14:40.958+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Group]
2017-10-04 13:14:40.958+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GroupMember
2017-10-04 13:14:40.959+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GroupMember]
2017-10-04 13:14:40.959+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes FileSystemDirectory
2017-10-04 13:14:40.960+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [FileSystemDirectory]
2017-10-04 13:14:40.961+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes StreamEntry
2017-10-04 13:14:40.962+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [StreamEntry]
2017-10-04 13:14:40.962+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EdgeThingPropertyNotification
2017-10-04 13:14:40.963+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EdgeThingPropertyNotification]
2017-10-04 13:14:40.963+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IntegerDeviationAlert
2017-10-04 13:14:40.965+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IntegerDeviationAlert]
2017-10-04 13:14:40.965+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DashboardItem
2017-10-04 13:14:40.966+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DashboardItem]
2017-10-04 13:14:40.972+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GenericEntry
2017-10-04 13:14:40.975+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GenericEntry]
2017-10-04 13:14:40.975+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataAnalysisJobData
2017-10-04 13:14:40.977+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataAnalysisJobData]
2017-10-04 13:14:40.977+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateFacets
2017-10-04 13:14:40.979+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateFacets]
2017-10-04 13:14:40.979+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ImageValueStream
2017-10-04 13:14:40.980+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ImageValueStream]
2017-10-04 13:14:40.980+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityNetwork
2017-10-04 13:14:40.981+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityNetwork]
2017-10-04 13:14:40.982+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AlertSummary
2017-10-04 13:14:40.983+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AlertSummary]
2017-10-04 13:14:40.983+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ServiceDefinition
2017-10-04 13:14:40.985+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ServiceDefinition]
2017-10-04 13:14:40.985+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LicenseInfoTableDataShape
2017-10-04 13:14:40.986+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LicenseInfoTableDataShape]
2017-10-04 13:14:40.992+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LicenseUsageDataShapeWithTimeStamp
2017-10-04 13:14:40.994+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LicenseUsageDataShapeWithTimeStamp]
2017-10-04 13:14:40.994+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingSpace
2017-10-04 13:14:40.996+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingSpace]
2017-10-04 13:14:40.996+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ScheduledEvent
2017-10-04 13:14:40.997+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ScheduledEvent]
2017-10-04 13:14:40.997+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MultilevelFacets
2017-10-04 13:14:40.998+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MultilevelFacets]
2017-10-04 13:14:40.998+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IndustrialGroups
2017-10-04 13:14:40.999+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IndustrialGroups]
2017-10-04 13:14:40.999+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NetworkConnection
2017-10-04 13:14:41.000+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NetworkConnection]
2017-10-04 13:14:41.000+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TunnelSession
2017-10-04 13:14:41.001+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TunnelSession]
2017-10-04 13:14:41.001+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TunnelStatus
2017-10-04 13:14:41.002+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TunnelStatus]
2017-10-04 13:14:41.009+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PropertyDefinition
2017-10-04 13:14:41.011+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PropertyDefinition]
2017-10-04 13:14:41.011+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityDescriptor
2017-10-04 13:14:41.013+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityDescriptor]
2017-10-04 13:14:41.013+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PropertyList
2017-10-04 13:14:41.014+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PropertyList]
2017-10-04 13:14:41.014+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NumberMatchAlert
2017-10-04 13:14:41.015+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NumberMatchAlert]
2017-10-04 13:14:41.015+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RouteIDList
2017-10-04 13:14:41.016+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RouteIDList]
2017-10-04 13:14:41.016+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntitySummary
2017-10-04 13:14:41.017+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntitySummary]
2017-10-04 13:14:41.017+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SystemStatistics
2017-10-04 13:14:41.019+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SystemStatistics]
2017-10-04 13:14:41.019+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PersistenceInformation
2017-10-04 13:14:41.020+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PersistenceInformation]
2017-10-04 13:14:41.027+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LongCompareAlert
2017-10-04 13:14:41.029+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LongCompareAlert]
2017-10-04 13:14:41.029+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Event
2017-10-04 13:14:41.030+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Event]
2017-10-04 13:14:41.030+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DeviceStatus
2017-10-04 13:14:41.031+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DeviceStatus]
2017-10-04 13:14:41.031+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IntegerRangeAlert
2017-10-04 13:14:41.033+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IntegerRangeAlert]
2017-10-04 13:14:41.033+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PropertyAlertSummary
2017-10-04 13:14:41.034+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PropertyAlertSummary]
2017-10-04 13:14:41.034+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NumberDeviationAlert
2017-10-04 13:14:41.035+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NumberDeviationAlert]
2017-10-04 13:14:41.035+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ApplicationKey
2017-10-04 13:14:41.037+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ApplicationKey]
2017-10-04 13:14:41.037+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Vocabulary
2017-10-04 13:14:41.038+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Vocabulary]
2017-10-04 13:14:41.044+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes VocabularyTermUsage
2017-10-04 13:14:41.046+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [VocabularyTermUsage]
2017-10-04 13:14:41.046+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TunnelEndpoint
2017-10-04 13:14:41.048+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TunnelEndpoint]
2017-10-04 13:14:41.048+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Vec2DataShape
2017-10-04 13:14:41.049+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Vec2DataShape]
2017-10-04 13:14:41.049+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Dashboard
2017-10-04 13:14:41.051+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Dashboard]
2017-10-04 13:14:41.051+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Difference
2017-10-04 13:14:41.054+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Difference]
2017-10-04 13:14:41.054+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SearchResults
2017-10-04 13:14:41.056+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SearchResults]
2017-10-04 13:14:41.056+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityCount
2017-10-04 13:14:41.057+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityCount]
2017-10-04 13:14:41.058+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AlertStatus
2017-10-04 13:14:41.059+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AlertStatus]
2017-10-04 13:14:41.069+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes FileTransferJob
2017-10-04 13:14:41.071+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [FileTransferJob]
2017-10-04 13:14:41.071+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Permissions
2017-10-04 13:14:41.072+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Permissions]
2017-10-04 13:14:41.072+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EditedEntities
2017-10-04 13:14:41.074+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EditedEntities]
2017-10-04 13:14:41.074+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Undefined
2017-10-04 13:14:41.075+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Undefined]
2017-10-04 13:14:41.075+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ChatMessage
2017-10-04 13:14:41.076+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ChatMessage]
2017-10-04 13:14:41.076+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ReadFromBinaryFileResult
2017-10-04 13:14:41.077+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ReadFromBinaryFileResult]
2017-10-04 13:14:41.077+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NotificationDefinitionNames
2017-10-04 13:14:41.079+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NotificationDefinitionNames]
2017-10-04 13:14:41.079+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateTimeCompareAlert
2017-10-04 13:14:41.081+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateTimeCompareAlert]
2017-10-04 13:14:41.086+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Role
2017-10-04 13:14:41.088+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Role]
2017-10-04 13:14:41.088+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes InfoTableMatchAlert
2017-10-04 13:14:41.089+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [InfoTableMatchAlert]
2017-10-04 13:14:41.089+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntryCommentEvent
2017-10-04 13:14:41.090+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntryCommentEvent]
2017-10-04 13:14:41.090+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RemoteEventBinding
2017-10-04 13:14:41.091+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RemoteEventBinding]
2017-10-04 13:14:41.091+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes WikiPageList
2017-10-04 13:14:41.092+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [WikiPageList]
2017-10-04 13:14:41.092+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes OrganizationConnection
2017-10-04 13:14:41.093+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [OrganizationConnection]
2017-10-04 13:14:41.093+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SubsystemStatus
2017-10-04 13:14:41.094+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SubsystemStatus]
2017-10-04 13:14:41.094+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AlertDefinition
2017-10-04 13:14:41.095+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AlertDefinition]
2017-10-04 13:14:41.100+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes UserOptions
2017-10-04 13:14:41.101+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [UserOptions]
2017-10-04 13:14:41.102+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ApplicationKeyExpirationInfo
2017-10-04 13:14:41.103+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ApplicationKeyExpirationInfo]
2017-10-04 13:14:41.103+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NamedVTQL
2017-10-04 13:14:41.105+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NamedVTQL]
2017-10-04 13:14:41.105+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BlogEntryWithComments
2017-10-04 13:14:41.106+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BlogEntryWithComments]
2017-10-04 13:14:41.106+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DatabaseCommandResults
2017-10-04 13:14:41.108+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DatabaseCommandResults]
2017-10-04 13:14:41.108+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateTimeMatchAlert
2017-10-04 13:14:41.110+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateTimeMatchAlert]
2017-10-04 13:14:41.110+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DashboardList
2017-10-04 13:14:41.112+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DashboardList]
2017-10-04 13:14:41.112+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AllPersistenceInformation
2017-10-04 13:14:41.113+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AllPersistenceInformation]
2017-10-04 13:14:41.118+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntryChangeEvent
2017-10-04 13:14:41.120+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntryChangeEvent]
2017-10-04 13:14:41.120+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes UserConfiguration
2017-10-04 13:14:41.121+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [UserConfiguration]
2017-10-04 13:14:41.121+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Vec3DataShape
2017-10-04 13:14:41.122+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Vec3DataShape]
2017-10-04 13:14:41.123+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes WikiHistory
2017-10-04 13:14:41.124+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [WikiHistory]
2017-10-04 13:14:41.124+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityDifference
2017-10-04 13:14:41.125+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityDifference]
2017-10-04 13:14:41.125+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BooleanMatchAlert
2017-10-04 13:14:41.126+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BooleanMatchAlert]
2017-10-04 13:14:41.126+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingworxMetric
2017-10-04 13:14:41.127+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingworxMetric]
2017-10-04 13:14:41.128+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingPackage
2017-10-04 13:14:41.129+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingPackage]
2017-10-04 13:14:41.136+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MenuItem
2017-10-04 13:14:41.137+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MenuItem]
2017-10-04 13:14:41.137+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataShape
2017-10-04 13:14:41.138+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataShape]
2017-10-04 13:14:41.138+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SystemStatisticsByDataType
2017-10-04 13:14:41.139+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SystemStatisticsByDataType]
2017-10-04 13:14:41.139+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateTimeValueStream
2017-10-04 13:14:41.140+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateTimeValueStream]
2017-10-04 13:14:41.140+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes StreamData
2017-10-04 13:14:41.141+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [StreamData]
2017-10-04 13:14:41.142+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateTimeDeviationAlert
2017-10-04 13:14:41.143+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateTimeDeviationAlert]
2017-10-04 13:14:41.143+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PropertyDefinitionWithDetails
2017-10-04 13:14:41.144+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PropertyDefinitionWithDetails]
2017-10-04 13:14:41.144+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataChangeEvent
2017-10-04 13:14:41.146+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataChangeEvent]
2017-10-04 13:14:41.150+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LocalizationToken
2017-10-04 13:14:41.152+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LocalizationToken]
2017-10-04 13:14:41.152+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataConnectSettings
2017-10-04 13:14:41.153+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataConnectSettings]
2017-10-04 13:14:41.154+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LongMatchAlert
2017-10-04 13:14:41.155+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LongMatchAlert]
2017-10-04 13:14:41.155+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ApplicationKeyExpirationInfoCollection
2017-10-04 13:14:41.155+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ApplicationKeyExpirationInfoCollection]
2017-10-04 13:14:41.156+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingStartEvent
2017-10-04 13:14:41.156+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingStartEvent]
2017-10-04 13:14:41.156+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EventDefinition
2017-10-04 13:14:41.157+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EventDefinition]
2017-10-04 13:14:41.157+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AnyDataChangeEvent
2017-10-04 13:14:41.158+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AnyDataChangeEvent]
2017-10-04 13:14:41.158+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PresenceChangeEvent
2017-10-04 13:14:41.159+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PresenceChangeEvent]
2017-10-04 13:14:41.164+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThreadPoolStats
2017-10-04 13:14:41.166+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThreadPoolStats]
2017-10-04 13:14:41.166+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ExtensionReportDataShape
2017-10-04 13:14:41.167+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ExtensionReportDataShape]
2017-10-04 13:14:41.167+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LocationMatchAlert
2017-10-04 13:14:41.168+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LocationMatchAlert]
2017-10-04 13:14:41.184+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityUsageReport
2017-10-04 13:14:41.186+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityUsageReport]
2017-10-04 13:14:41.186+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LocalPropertyBinding
2017-10-04 13:14:41.188+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LocalPropertyBinding]
2017-10-04 13:14:41.188+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ObjectAttribute
2017-10-04 13:14:41.190+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ObjectAttribute]
2017-10-04 13:14:41.190+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Subscription
2017-10-04 13:14:41.191+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Subscription]
2017-10-04 13:14:41.191+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ConnectionStatus
2017-10-04 13:14:41.192+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ConnectionStatus]
2017-10-04 13:14:41.201+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes FileSystemFileWithLinks
2017-10-04 13:14:41.203+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [FileSystemFileWithLinks]
2017-10-04 13:14:41.203+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LocalizationTokenAnnotated
2017-10-04 13:14:41.204+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LocalizationTokenAnnotated]
2017-10-04 13:14:41.204+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SecurityEvent
2017-10-04 13:14:41.205+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SecurityEvent]
2017-10-04 13:14:41.205+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NumberValueStream
2017-10-04 13:14:41.206+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NumberValueStream]
2017-10-04 13:14:41.206+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DateTimeRangeAlert
2017-10-04 13:14:41.207+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DateTimeRangeAlert]
2017-10-04 13:14:41.207+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Vec4DataShape
2017-10-04 13:14:41.208+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Vec4DataShape]
2017-10-04 13:14:41.208+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityList
2017-10-04 13:14:41.209+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityList]
2017-10-04 13:14:41.209+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ExtensionPackage
2017-10-04 13:14:41.215+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ExtensionPackage]
2017-10-04 13:14:41.221+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AlertHistory
2017-10-04 13:14:41.222+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AlertHistory]
2017-10-04 13:14:41.223+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MenuEntry
2017-10-04 13:14:41.224+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MenuEntry]
2017-10-04 13:14:41.224+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LegacyEdgeThingPropertyNotification
2017-10-04 13:14:41.225+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LegacyEdgeThingPropertyNotification]
2017-10-04 13:14:41.226+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes UserExtensionsData
2017-10-04 13:14:41.227+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [UserExtensionsData]
2017-10-04 13:14:41.227+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LicenseStatusShape
2017-10-04 13:14:41.228+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LicenseStatusShape]
2017-10-04 13:14:41.228+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BulkProcessingReport
2017-10-04 13:14:41.229+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BulkProcessingReport]
2017-10-04 13:14:41.229+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GenericStringList
2017-10-04 13:14:41.230+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GenericStringList]
2017-10-04 13:14:41.230+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingFacets
2017-10-04 13:14:41.232+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingFacets]
2017-10-04 13:14:41.239+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ConnectorStatus
2017-10-04 13:14:41.241+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ConnectorStatus]
2017-10-04 13:14:41.241+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RemotePropertyUpdates
2017-10-04 13:14:41.243+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RemotePropertyUpdates]
2017-10-04 13:14:41.243+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes StringMatchAlert
2017-10-04 13:14:41.244+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [StringMatchAlert]
2017-10-04 13:14:41.245+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RunTimePermissions
2017-10-04 13:14:41.246+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RunTimePermissions]
2017-10-04 13:14:41.246+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LockedUsers
2017-10-04 13:14:41.247+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LockedUsers]
2017-10-04 13:14:41.247+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IntegerMatchAlert
2017-10-04 13:14:41.248+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IntegerMatchAlert]
2017-10-04 13:14:41.248+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes VTQ
2017-10-04 13:14:41.249+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [VTQ]
2017-10-04 13:14:41.249+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes InfoTableCompareAlert
2017-10-04 13:14:41.250+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [InfoTableCompareAlert]
2017-10-04 13:14:41.260+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PropertyAlertSummaryDetail
2017-10-04 13:14:41.261+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PropertyAlertSummaryDetail]
2017-10-04 13:14:41.261+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DashboardChange
2017-10-04 13:14:41.262+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DashboardChange]
2017-10-04 13:14:41.262+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes VocabularyTermList
2017-10-04 13:14:41.264+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [VocabularyTermList]
2017-10-04 13:14:41.264+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DatabaseTable
2017-10-04 13:14:41.265+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DatabaseTable]
2017-10-04 13:14:41.265+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SubscriberStatus
2017-10-04 13:14:41.266+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SubscriberStatus]
2017-10-04 13:14:41.266+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Menu
2017-10-04 13:14:41.267+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Menu]
2017-10-04 13:14:41.267+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MashupFacets
2017-10-04 13:14:41.268+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MashupFacets]
2017-10-04 13:14:41.269+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NumberRangeAlert
2017-10-04 13:14:41.269+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NumberRangeAlert]
2017-10-04 13:14:41.276+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NumberCompareAlert
2017-10-04 13:14:41.277+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NumberCompareAlert]
2017-10-04 13:14:41.277+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes StreamEntryWithValues
2017-10-04 13:14:41.277+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [StreamEntryWithValues]
2017-10-04 13:14:41.278+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GetTransferInfoResult
2017-10-04 13:14:41.278+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GetTransferInfoResult]
2017-10-04 13:14:41.278+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes CollaborationSearchResult
2017-10-04 13:14:41.279+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [CollaborationSearchResult]
2017-10-04 13:14:41.279+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AlertEvent
2017-10-04 13:14:41.280+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AlertEvent]
2017-10-04 13:14:41.280+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NamedFacets
2017-10-04 13:14:41.281+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NamedFacets]
2017-10-04 13:14:41.281+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes VTQL
2017-10-04 13:14:41.281+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [VTQL]
2017-10-04 13:14:41.281+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PersistenceSchemaMetadata
2017-10-04 13:14:41.282+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PersistenceSchemaMetadata]
2017-10-04 13:14:41.288+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ActiveDirectoryDomainGroups
2017-10-04 13:14:41.289+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ActiveDirectoryDomainGroups]
2017-10-04 13:14:41.289+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IntegerCompareAlert
2017-10-04 13:14:41.290+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IntegerCompareAlert]
2017-10-04 13:14:41.290+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RemoteEventUpdates
2017-10-04 13:14:41.291+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RemoteEventUpdates]
2017-10-04 13:14:41.291+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ServiceImplementation
2017-10-04 13:14:41.292+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ServiceImplementation]
2017-10-04 13:14:41.292+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TimeIndexBucket
2017-10-04 13:14:41.294+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TimeIndexBucket]
2017-10-04 13:14:41.294+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes InfoTableValueStream
2017-10-04 13:14:41.295+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [InfoTableValueStream]
2017-10-04 13:14:41.295+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes SystemInformation
2017-10-04 13:14:41.295+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [SystemInformation]
2017-10-04 13:14:41.296+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes PeopleFacets
2017-10-04 13:14:41.296+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [PeopleFacets]
2017-10-04 13:14:41.301+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MessageStoreList
2017-10-04 13:14:41.303+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MessageStoreList]
2017-10-04 13:14:41.303+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ExtensionInfoDataShape
2017-10-04 13:14:41.304+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ExtensionInfoDataShape]
2017-10-04 13:14:41.304+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Principal
2017-10-04 13:14:41.305+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Principal]
2017-10-04 13:14:41.305+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes StringValueStream
2017-10-04 13:14:41.306+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [StringValueStream]
2017-10-04 13:14:41.306+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TimeSeriesDataset
2017-10-04 13:14:41.307+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TimeSeriesDataset]
2017-10-04 13:14:41.307+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IndustrialItems
2017-10-04 13:14:41.309+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IndustrialItems]
2017-10-04 13:14:41.309+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RemotePropertyBinding
2017-10-04 13:14:41.310+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RemotePropertyBinding]
2017-10-04 13:14:41.310+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LongValueStream
2017-10-04 13:14:41.312+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LongValueStream]
2017-10-04 13:14:41.327+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes FieldDefinition
2017-10-04 13:14:41.328+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [FieldDefinition]
2017-10-04 13:14:41.328+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ScriptServiceResult
2017-10-04 13:14:41.329+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ScriptServiceResult]
2017-10-04 13:14:41.329+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes MashupList
2017-10-04 13:14:41.329+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [MashupList]
2017-10-04 13:14:41.329+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GenericResult
2017-10-04 13:14:41.330+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GenericResult]
2017-10-04 13:14:41.330+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingCodeDataShape
2017-10-04 13:14:41.331+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingCodeDataShape]
2017-10-04 13:14:41.331+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityDescriptorWithTimestamp
2017-10-04 13:14:41.331+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityDescriptorWithTimestamp]
2017-10-04 13:14:41.331+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes NotificationHandlers
2017-10-04 13:14:41.332+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [NotificationHandlers]
2017-10-04 13:14:41.332+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes HandlerDefinition
2017-10-04 13:14:41.333+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [HandlerDefinition]
2017-10-04 13:14:41.339+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes WikiPageWithComments
2017-10-04 13:14:41.340+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [WikiPageWithComments]
2017-10-04 13:14:41.340+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IntegerValueStream
2017-10-04 13:14:41.340+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IntegerValueStream]
2017-10-04 13:14:41.341+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes GeoFencePoint
2017-10-04 13:14:41.341+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [GeoFencePoint]
2017-10-04 13:14:41.341+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingStreamEntry
2017-10-04 13:14:41.342+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingStreamEntry]
2017-10-04 13:14:41.342+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LongDeviationAlert
2017-10-04 13:14:41.343+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LongDeviationAlert]
2017-10-04 13:14:41.343+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Resource
2017-10-04 13:14:41.345+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Resource]
2017-10-04 13:14:41.345+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Recipient
2017-10-04 13:14:41.346+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [Recipient]
2017-10-04 13:14:41.346+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataFacets
2017-10-04 13:14:41.347+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataFacets]
2017-10-04 13:14:41.352+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes CollaborationFacets
2017-10-04 13:14:41.353+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [CollaborationFacets]
2017-10-04 13:14:41.353+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes FileSystemFile
2017-10-04 13:14:41.354+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [FileSystemFile]
2017-10-04 13:14:41.354+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ScriptFunctionLibrary
2017-10-04 13:14:41.355+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ScriptFunctionLibrary]
2017-10-04 13:14:41.355+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DatabaseColumn
2017-10-04 13:14:41.355+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DatabaseColumn]
2017-10-04 13:14:41.355+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EventDescriptor
2017-10-04 13:14:41.356+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EventDescriptor]
2017-10-04 13:14:41.356+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ConfigurationTable
2017-10-04 13:14:41.357+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ConfigurationTable]
2017-10-04 13:14:41.358+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingEntry
2017-10-04 13:14:41.358+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingEntry]
2017-10-04 13:14:41.358+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DashboardGroup
2017-10-04 13:14:41.359+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DashboardGroup]
2017-10-04 13:14:41.364+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes DataTableEntry
2017-10-04 13:14:41.365+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [DataTableEntry]
2017-10-04 13:14:41.365+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ThingShape
2017-10-04 13:14:41.366+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ThingShape]
2017-10-04 13:14:41.366+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntitySearchResult
2017-10-04 13:14:41.366+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntitySearchResult]
2017-10-04 13:14:41.367+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes IndustrialThingPropertyNotification
2017-10-04 13:14:41.367+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [IndustrialThingPropertyNotification]
2017-10-04 13:14:41.367+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LicenseUsageDataShape
2017-10-04 13:14:41.368+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LicenseUsageDataShape]
2017-10-04 13:14:41.368+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BoundName
2017-10-04 13:14:41.368+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BoundName]
2017-10-04 13:14:41.368+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LocationDeviationAlert
2017-10-04 13:14:41.369+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LocationDeviationAlert]
2017-10-04 13:14:41.369+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes TagFacets
2017-10-04 13:14:41.370+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [TagFacets]
2017-10-04 13:14:41.375+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes EntityReference
2017-10-04 13:14:41.376+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [EntityReference]
2017-10-04 13:14:41.376+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes RemoteServiceBinding
2017-10-04 13:14:41.377+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [RemoteServiceBinding]
2017-10-04 13:14:41.377+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes UserPermissions
2017-10-04 13:14:41.378+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [UserPermissions]
2017-10-04 13:14:41.378+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes BlogHistory
2017-10-04 13:14:41.379+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [BlogHistory]
2017-10-04 13:14:41.379+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes LogEntry
2017-10-04 13:14:41.380+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [LogEntry]
2017-10-04 13:14:41.380+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes ConfigurationChange
2017-10-04 13:14:41.381+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [ConfigurationChange]
2017-10-04 13:14:41.381+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes AllPersistenceSchemaMetadata
2017-10-04 13:14:41.382+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape [AllPersistenceSchemaMetadata]
2017-10-04 13:14:41.382+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Processing DataShapes Comment
2017-10-04 13:14:41.383+0530 [L: INFO] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Successfully added DataShape --> --> --> --> -->
Hi Shubham,
This line in your application log :
2017-10-04 13:14:45.302+0530 [L: ERROR] [O: .t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] C:\ThingworxPlatform;\license.bin: license file does not exist!"
says the license.bin doesn't exist in the ThingworxPlatform folder.
Did you create the ThingworxPlatform folder in your root directory and place your license.bin inside the folder? Also make sure you have read and write permissions for the ThingworxPlatform folder.
yes I did  ,also I have given required permissions to it & set the appropriate environment variable for that
Hi Shubham,
Have you set the library path to the PATH variable in the system environment variables?
If you haven't done so, could you please try the steps given in the following thread and let us know the result:
https://community.thingworx.com/community/developers/blog/2017/04/12/74-thingworx-does-not-launch-due-to-license-error-in-windows
Tried that as well but no help
Hi Shubham,
Could you also please review if ThingworxPlatform and license.bin file has full control access to the user as shown below:
Shubham,
Also try the workaround given in this article. Article Viewer | PTC
