Issue on stream (no value stream)
dbologna1
I All,
I created a new Stream 'TEST' form a DataShape like the following
I also created a service to store information in Stream by service AddStreamEntry().
With a service QueryStreamData() I saw all the rows stored into Stream.
I create a new service to get a subset of data from the stream using StartDate and EndDate but for both solution I didn't receceive return values.
FIRST TEST :
I set the date on the parameters like
var params = {
    oldestFirst: undefined /* BOOLEAN */,
    maxItems: undefined /* NUMBER */,
    sourceTags: undefined /* TAGS */,
    endDate: DateEnd /* DATETIME */,
    query: undefined /* QUERY */,
    source: undefined /* STRING */,
    startDate: DateStart /* DATETIME */,
    tags: undefined /* TAGS */
No output was  found, but there are into Stream  some data  between StartDate and EndDate.
SECOND TEST:
I creare a filter like
var date_start=DateStart.getTime();
var date_end=DateEnd.getTime();
my_query={
            "filters": {
                "type":"Between",
                "fieldName":"timestamp",
                "from": date_start,
                 "to":date_end
and put this into paramters like
var params = {
    endDate: undefined /* DATETIME */,
    query: My_query /* QUERY */,
    startDate: undefined /* DATETIME */,
Also in this case no output was found.
Please, anyone can give me some suggestions.
Many Thanks
BR
Dimitri
Screenshot of result:
Hi Dimitri Bologna​,
I just tested this scenario on ThingWorx version 7.4 and it works fine.
Here is my code:
var params = {
    endDate: EndDate /* DATETIME */,
    startDate: StartDate /* DATETIME */,
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryStreamData(params);
Could you please confirm the ThingWorx version you are on?
Hi Ankit,
many thanks for your answer.
I'm using the Thingworx 7.4
Now the service is working.
Maybe I had inverted the dates.
Sorry Ankit, is it possible to define a fixed ored of the parameters into Test mashup ?
Many Thanks
Dimitri
Things to check: select start date and end date in correct order. Sometimes end date variable show before start date and we select them incorrectly.
Output of the service is an infotable.
