Issue with Date Picker on TWX V 9.5
Bikash_Panda
I am using a date picker widget on a popup  on ThingWorx 9.5, for some reason when I select a data from the calendar, the pop-up closes automatically. Is it a known bug? and is there any work around?
Thanks in advance.
@Bikash_Panda , I assume you are using the Navigate function to open the popup mashup. When you configure the Navigation, Have you selected "Click Outside to Close"?
If you remove "Click Outside to Close" does the popup display more like you expect?
2 REPLIES 2
Bikash_Panda
(To:PEHOWE)
Thanks for the info. Yes its workifg as expected now.
