I use that widget with a mask like
9999-9999-9999-a
from desktop web browser it works fine,
but from a mobile phone at the first number pressed, the cursor goes back of 1 and so the first group of 4 number is get in a wrong way.
By pressing 12345 I get
2345-1____-____-_
instead of
1234-5___-____-_
is there a fix
I have thingworx 8.5.16
Hello @slangley
The issue can be fixed with this workaround that was made (by you) for another issue on the same widget
Hi @iguerra.
Unfortunately, 8.5 is no longer supported. However, there have been some improvements in the 9.x releases. We tested under TWX 9.2.3 and it worked on iOS 14.8. We don't have an Android phone for testing.
--Sharon
Hello @slangley
