Hi @AViñeta,
Query Property History is a bit strange to work with if you use it the first times.
There is good documentation available in the help center here: https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/DataStorage/ValueStreams/UsingTheQueryPropertyHistoryService.html and as a Technical Support article here, https://www.ptc.com/en/support/article/cs226000
But, in short:
The maxItems means the max number of rows that the service will use internally to get from the Value Stream data. If you have 10 properties, the service will get the last [maxItems] number of data points for each property, and then (this is where it gets interesting) it will combine the resulted 10 tables into a single one that you see in Composer. The combination algorithm makes sure that for each unique timestamp it tries the best it can to populate values for ALL properties - even if the timestamps are different. That's the tricky part: depending on how different the timestamps are, you could have either 0 rows (minimum) or 100 rows (10 properties x 10 different timestamps). It all depends on the timestamps you store in the Value Stream. And, also, depending on the start or end Date, you might end-up with missing values, if the algorithm can not locate a proper value. Remember that when maxItems is empty is also replaced with a default of 500 rows.
Regardless, the links I shared above probably will provide enough information to help you bypass this issue, with some experimentation.
